altering stroke on a crank
tavspeed
hi all,anyone altered the stroke on a crank by filling the existing pin holes,with either a 22mm plug and welding it in,or filling the holes with mig weld and re drilling and reaming out to suit the 22mm crank pin,which i would tig weld in,cheers all.
gaz_powell
be easier to by an eccentric crank pin
tavspeed
yeah i think readspeed do 62mm for about £80 quid,i could do this at work,probaly get one out to 64mm,but then you have issues with the conrod catching the casing,anyone got any knackered indian gp cranks to have a go on,cheers.
tavspeed wrote:yeah i think readspeed do 62mm for about £80 quid,i could do this at work,probaly get one out to 64mm,but then you have issues with the conrod catching the casing,anyone got any knackered indian gp cranks to have a go on,cheers.
thats good to know ...im assuming that price is to rebuild /convert ......ill have a peek :bouncyeng:
carlos fandango
I think thats just to buy the pin :D
yeah probbably :roll: :(
tavspeed
yep,thats just for the pin,this is going to be a credit crunch engine,the budget is so tight it squeaks :biggrin:
I seem to remember Taffspeed altering the stroke on Lambretta cranks back in the 80's. They re-drilled new holes 180' to the old crank pin holes then plugged the old holes. Just a thought.
grimspeed
Main scooter: gp 283 kx
Readspeed do up to a 64mm crank at £286.00
    Users browsing this forum: Semrush [Bot] and 9 guests
