clutch arm length
cvjosh
Main scooter: 150special
i have spanish SX casings and just put a AF clutch in and it feels like it wont disengage all the way when the clutch is pulled in...
i have adjusted it correctly but is their a difference in clutch arm length from a SX to a GP ???
help me get this guy back on the road please :)
no ..but a shortend arm will pull more for less travel ...just be a touch harder to pull lever in
have you fitted gp side case at all ??
cvjosh
I have the sx side casing would a gp side casing change how the clutch would work ?
you dont say what af clutch you are using if it has a gp type centre or the new cassette type it will not work with a sx / li type case
cvjosh
I bought the gp style one ...
So I have to replace The whole side casing? Or just the clutch actuating arm?
as the sx type clutch center has a pin and thimble fitting the gp type will then place it to far away from the pawl in the side case ,a gp side case has a bronze pad that fitts into a casting which is not present on the sx/li type so yes you do need a gp side case
just to point out this pic was to show that the pawl was fitted wrong
