RB not revving out.
micksnake
Main scooter: GP.TS1 225
Any ideas lads, mates RB 225 kicks up, ticks over, revs ok but brickwalls at high revs but ok if you pull out yellow wire from stator to regulator. Tried 3 stators changed regulator and CDI.
jason frost
Have you taken the green wire from the loom out of the CDI?
micksnake
Yes Jason, bypassed ignition and tried a new MB one also mate.
Diablo
What CDI are you using? Believe it or not the blue Ducati ones often don't work well with indian stators.
Try the AF one if this is the case.
micksnake
AF flywheel, tried another AF one even worse put a standard indian on revved through. F@#king Lambys dont you just luv em.
jason frost
micksnake wrote:AF flywheel, tried another AF one even worse put a standard indian on revved through. F@#king Lambys dont you just luv em.
New AF one ? could be the hight of the pick up, just funny taking the yellow power wire out stopped it :?
It may not have had a bearing on the loss of power but with the regulator connected to the stator there will always be a load applied as with the lights off, the regulator will burn off the excess power in the form of heat. Taking the yellow wire out would remove the load and would allow the engine to rev more.
micksnake
Just had a call off my mate, had the flywheel lightened put it on and back to square one not revving out.
Chris CSPE
Is it the re'made AF Ducati fly wheel, has the inside of the mag housing been machined down at all.
    Users browsing this forum: Majestic-12 [Bot] and 7 guests
