Anyone had the same problem
Wont turn off!
- Andy Pickering
- registered user
- Main scooter: GP
- Contact:
Been for a play this afternoon after fitting new carb..All fine then went to turn off and it kept running..Simple poor earth
...checked all earths and there fine, checked ignition for loose wires but there fine. Now the strange bit....it wont start with the key turned to off but it will start in the on postion but wont turn off :flaming:...New one on me this
..New ignition by the way and not a cheap one
Pre ignition?
- Andy Pickering
- registered user
- Main scooter: GP
- Contact:
firekdp wrote:Pre ignition?
No dont think so..hope not it was fine before changing carb.
Have you checked the ignition switch with a multimeter?
- Andy Pickering
- registered user
- Main scooter: GP
- Contact:
Dont have one..firekdp wrote:Have you checked the ignition switch with a multimeter?
Fireman Ash
- registered user
- Contact:
Any wires broken, stretched? multi-meter may find a break if you do a continuity test? cheap on the web and worth a few quid for future electrical probs
- Andy Pickering
- registered user
- Main scooter: GP
- Contact:
I will have a word with my electricians at work in the morning...would it be the same as a tester for mains electric
I'm concerned that since fitting the new carb you are running too lean, therefore too hot and the fuel is self-igniting.
If i'm right and you keep running like it, you'll hole the piston or sieze.
Check the plug colour before running it again.
- Andy Pickering
- registered user
- Main scooter: GP
- Contact:
Will do andy...Could be lean as ive got the AS atomiser in until morning when the AV266 turns up that will rich it back up..plug was very pale thats why i put it away..Ran lovely though..was a tad hot though could smell it..Daggs wrote:I'm concerned that since fitting the new carb you are running too lean, therefore too hot and the fuel is self-igniting.
You may need to up the main jet rather than the atomiser.
- Information
Who is online
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 4 guests
