Wont turn off!
Been for a play this afternoon after fitting new carb..All fine then went to turn off and it kept running..Simple poor earth :lol: ...checked all earths and there fine, checked ignition for loose wires but there fine. Now the strange bit....it wont start with the key turned to off but it will start in the on postion but wont turn off :flaming:...New one on me this :(
Anyone had the same problem :?: ..New ignition by the way and not a cheap one :!:
firekdp
Pre ignition?
firekdp wrote:Pre ignition?
No dont think so..hope not it was fine before changing carb.
firekdp
Have you checked the ignition switch with a multimeter?
firekdp wrote:Have you checked the ignition switch with a multimeter?
Dont have one..
Fireman Ash
Any wires broken, stretched? multi-meter may find a break if you do a continuity test? cheap on the web and worth a few quid for future electrical probs
I will have a word with my electricians at work in the morning...would it be the same as a tester for mains electric :!:
Daggs
I'm concerned that since fitting the new carb you are running too lean, therefore too hot and the fuel is self-igniting.
If i'm right and you keep running like it, you'll hole the piston or sieze.
Check the plug colour before running it again.
Daggs wrote:I'm concerned that since fitting the new carb you are running too lean, therefore too hot and the fuel is self-igniting.
Will do andy...Could be lean as ive got the AS atomiser in until morning when the AV266 turns up that will rich it back up..plug was very pale thats why i put it away..Ran lovely though..was a tad hot though could smell it..
Daggs
You may need to up the main jet rather than the atomiser.
