gp200 bogging
Nighteditor
Main scooter: GP200
Hi,
Any help would be appreciated, just bought a gp200 with a new sil stage4 engine the head has been ported and is now fitted with a sterling stainless exhaust, and i think a jetex 24mm, she starts second kick from cold ans first from hot ticks over ok...when i take her for a run she goes ok up to third and when i change to fourth she bogs and almost stalls and has done once.
I have drilled the air box and she still does it maybe she is now getting to much air, not sure really, i was told to drill the atomiser 2.1mm through and 1mm top hole to stop it bogging or start playing with main jets.
anyone else had the same problem
cheers kev. :?
Donnie
first thing to do is to
1. ditch the stainless sterling, it'll crack and probably f@@k the top end.
2. Find out if it is definitely a 22 or 24 jetex
3. tell us what idle jet, atomiser, slide and main jet you have in there.
4. how long have you had it, ie just bought it or is it definitely run in already?
Donnie.
Donnie
oops just noticed you say a new sil engine, is this from a dealer or a private sale?
Donnie.
poose
Had loads of problems with Jetex carbs, they either work or they dont, ditch it for summat else.
Donnie
whoaaaa there, might be better to get all the correct information first surely???
Donnie.
joespeed
do you know what gearbox it has in it?i keep coming across the gp150 vj box it has a rediculous jump from 3rd to 4th and big sprockets on the crank end!
if the engine runs something like in the lower gears i would check this.
regards
joe
Nighteditor
Main scooter: GP200
Hi,
the carb is defo a 22mm jetex the main jet is 118 choke jet is 50 and the slow running is a 45
its just run in
Any chance you could get your hands on a 30 mil dellorto maybe borrow one off a mate, there's loads of proven set ups with this carb..I've searched here and the net and not much set up info with that exhaust and standard carb..the delly would bring better performance from the pipe..
You should reveal your location as someone local might be able to help.
Danger
Main scooter: lambretta TV200
i just did some work on a gp200 there the fella said the engine was new it also had a brand new sterling on it an a brand new 22mil jetex totaly standard an it goes like feck an pulls like a train i was really surprised at how well it went very revvy tho with the sterling
Nighteditor
Main scooter: GP200
Lam46 wrote:Any chance you could get your hands on a 30 mil dellorto maybe borrow one off a mate, there's loads of proven set ups with this carb..I've searched here and the net and not much set up info with that exhaust and standard carb..the delly would bring better performance from the pipe..
Hi im from wrexham, was told to ditch the sterling it is a bit revvy but brand new with the scoot so id like to get it running right and maybe ditch it later, had the carb off today, clean as a whistle... the carb is new also and the engine has just been run in, was not bad just toodling around but when i went through the gears and gave it some in fourth it just bogged, just like you go from full tank to reserve, then when i eased off it came back.
starts ticks over fine, its a jetex with standard jets 50 choke, 45 slow running and 118 main jet, ive drilled the atomiser 2.1 down the main and 1mm top cross hole, all back to gether and stars first time and runs ok..will test run it tomorrow....keep you all posted
    Users browsing this forum: Majestic-12 [Bot], Semrush [Bot] and 17 guests
