.... for Lambrettas.
I'm selling them with tyres mounted for those who aren't sure about getting them fitted.
Rim £56, Schwalbe 3.50 x 10 Raceman or Weatherman £37, fitting £5, P&P £8. 1 = £106, 2 = £204, 3 = £300.
£3 per tyre more for Whitewall Weatheman.
SIP tubeless rims with tyres fitted...
- drunkmunkey6969
- Moderator
- Contact:
Are they the new 'Mk2' version....and do you do the matt black ones too?
Af do matt black not sip, I have both a silver sip which is pure quality with a deeper well thicker body area , longer studs and all the nuts and washers which racemans fit to easy and a matt black Af one which doesn't do any of the above
- soulsurfer
- registered user
- Contact:
SIP do matt black and matt black with polished edge...
http://www.sip-scootershop.com/main/bas ... a=1&sort=0
[Edit] ...and so does Martin
- corrado
- Dealer
- Main scooter: Lambretta GP
- Contact:
Yes Dan, they're as Mark says.
I have got them in Matt Black, Black with polished lip (mmmm) and Silver. I've not got the polished alloy ones at the minute.
Keep quiet about it as I am "JUST"Lambretta ...... but I've also got Veshpa ones too in Black with polished lip, Silver and polished alloy.
As a rule I don't like Whitewalls but the Black with polished lip and Whitewall Weathermans do look the dogs danglies.
- Doom Patrol
- registered user
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
- Contact:
Is it wrong to lust after a wheel rim?
- soulsurfer
- registered user
- Contact:
You're right about the white walls. Nice
bristolmod
- registered user
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
- Contact:
yes- they look very nice indeed.
Just to clarify. Simply remove old wheel and pop on new wheel? No fettling required at all?
Chris
Chris
Scootering since 1968.
Take off wheel , remove old hub studs, fit new hub studs refit wheel
