SIP tubeless rims with tyres fitted...
.... for Lambrettas.
I'm selling them with tyres mounted for those who aren't sure about getting them fitted.
Rim £56, Schwalbe 3.50 x 10 Raceman or Weatherman £37, fitting £5, P&P £8. 1 = £106, 2 = £204, 3 = £300.
£3 per tyre more for Whitewall Weatheman.
Are they the new 'Mk2' version....and do you do the matt black ones too?
Af do matt black not sip, I have both a silver sip which is pure quality with a deeper well thicker body area , longer studs and all the nuts and washers which racemans fit to easy and a matt black Af one which doesn't do any of the above
SIP do matt black and matt black with polished edge...
http://www.sip-scootershop.com/main/bas ... a=1&sort=0
[Edit] ...and so does Martin :D
Yes Dan, they're as Mark says.
I have got them in Matt Black, Black with polished lip (mmmm) and Silver. I've not got the polished alloy ones at the minute.
Keep quiet about it as I am "JUST"Lambretta ...... but I've also got Veshpa ones too in Black with polished lip, Silver and polished alloy.
As a rule I don't like Whitewalls but the Black with polished lip and Whitewall Weathermans do look the dogs danglies.
Is it wrong to lust after a wheel rim? :lol:
Weatherman Whitewalls on Matt Black rims....
Racemans on Silver rims ....
Racemans on Matt Black rims ....
Weathermans on Black rims with polished lip ....
You're right about the white walls. Nice :-)
bristolmod
yes- they look very nice indeed.
Just to clarify. Simply remove old wheel and pop on new wheel? No fettling required at all?
Chris
Scootering since 1968.
Take off wheel , remove old hub studs, fit new hub studs refit wheel
