Mag Housing
#1GP200
Got an Li125 casing and mag housing. Fitting a GP crank and NU2205 bearing.
Can i use the original mag housing or do i need a GP housing ?
Cheers.
Robi D
You should be just fine with the original. Only the ser. 1 mag housings are different.
#1GP200
Cheers Robi was hoping that was the case.
TS1-200
Don`t forget to leave out the spacer in the bearing housing, as the GP mag bearing is wider than the SX/LI one.
Keep on keepin on
