Ballpark jetting for a 25mm Dellorto
LI150
Main scooter: Series 2 LI150
Anyone got any ballpark settings for a Standard 200 running a AF clubman please.. 8-)
LI150
Anyone ??
Killkenny
open bellmouth of filtered? Air box? remote? need more info fella.
LI150
Running through an airbox. 8-)
Killkenny
well this is what Id use on a 25 Phbl (presuming the airbox has been drilled to let more air in) on a standard with clubman for a good starting point
98-100 main
48 idle
Dq 262 atomiser
D22 second clip from top
air mix screw 1+ half turns out
40 slide
2.5 needle valve
should get you something like near
LI150
Thank you
