removing flywheel side bearing VBA
biminyrd
Main scooter: 1961 Li125
I split the cases on a 1959 VBA, and the flywheel side bearing didn't come out with the crank.
How do I remove the flywheel side bearing? I've got some of the factory bearing pullers, but I can't remove the flyside seal to push the puller through. All the online how to's have this bearing coming out with the crank.
what's the trick with out destroying the bearing?
thanks,
aaron
al-super3
Lots of heat on the case and it should drop out. I would put new bearing in anyway
Hope this helps Cheers Al
Scream at me until my ears bleed
biminyrd
Thanks! got it out pretty easy.
    Users browsing this forum: No registered users and 47 guests
