T5 classic front wheel
Tosh
when fitting the front hub is there a plain washer under the nut before you get to the circlip,in the haynes manual its shows one,on page 97 but on page 99 its not in the breakdown assembly :? ,so that would mean that the hub nut would go straight to the bearing an rest on the inner face,
Chris.
Main scooter: Vespa PX208
I've just split my P2 Disc, and it had hub bearing, circlip, washer, nut, castle nut, split pin.
gaz_powell
washers were not used in early and efl but i couldn`t voucher for disc - however i fitted a grimeca classic and a piaggio new disc hub set up and never fitted a washer to no detriment
Tosh
thanks both for the replys,will av to keep going with head down and see.
Paul
