yamaha pistons
sjc
is there any difference between a dt175 piston and a it 175 piston? many thanks steve...
J1MS
YES.
Ring peg positioning is further apart on the IT....
sjc
got a steel linered mb stage 2 ts1200 runnin 115mm conrod,, with a dt 175 piston,just wondered if you run the it 175 as they are easier to get hold of cheers steve..
J1MS
I think the IT piston is more suited to the TS1 200.
sjc
its either the it piston or a mb racetour but alot of money difference,,
Fruitjuice
The IT175 or YZ175 pistons are easy to get hold of and come pretty cheap, I've used the Wiseco forged pistons twice with good results, but the MB-site says they've experienced ring peg failure with these in the past... There's also a Wossner-version about, but haven't tried that yet...
My kit had a reprofiled head, so not sure the dome on the Yamaha/Wiseco-piston is the same as on the original Asso-piston...
J1MS
Yes you will need to re-profile the head if switching from An asso piston to a yamaha IT but if you already use a Yamaha DT piston the profile should be OK.
mickdale
wossner IT 175 piston - superb light racing piston with coated skirt @ 66 quid?
over here in houston they are using ceramic thermal coating (sprayed on) that resists heat transfer from the combustion chamber - as it wont cost, might get my crown done?????
will speak to harry when im back in the uk about it
gaz_powell
MB used to use the IT and not the DT (the it piston ring pegs are as the asso piston)
The IT piston you want is the 1980-1981 3R6
good place is ebay - there`s always a good supply in america for good prices and they use DT rings
Rosi-C9
Left: Wiseco DT 175 471M06700 used in my T5 Yam Conversion
Right: Wiseco IT 175 374M06600 used in my TS1 200
