air cooled auto engine temperature
WINTERMODEL150
Hi,does anyone know the engine temperature that an air cooled typhoon 172 should run at?
bicboy
Main scooter: S2, EID Built, Diablo tuned...
Bet this gets moved to the Automatix Section, under duress from the moderators :D
Everything must be done to the Extreme.....
bicboy wrote:Bet this gets moved to the Automatix Section, under duress from the moderators :D
Lol..prob best moved to auto section wintermodel to get the answer your looking for.............bicboy extreme good behaviour needed flower.. :frog:
bicboy
:mrgreen: :mrgreen: :mrgreen:
tony
Main scooter: 90ss
A two stroke is a two stroke..
Head temp or barrel temp? I guess the sensor is on the head. 90 tops I'd say.
WINTERMODEL150
just looking for a fast running temp from the engine, spark plug would be better.
i understand 90 is for a water cooled engine but i seemed to think air cooled engines run a lot hotter than this.
Diablo
On the one fitted to Dave Workmans Rally the temp gauge was reading between 220 and 265 degrees fahrenheit. The scoots done a few hundred miles now so I guess on this bike at least thats safe.
WINTERMODEL150
Thanks diablo sounds about the right temp for an air cooled 8-)
