air cooled auto engine temperature
- Main scooter: lambretta ld auto
Hi,does anyone know the engine temperature that an air cooled typhoon 172 should run at?
- Andy Pickering
- Main scooter: GP
Lol..prob best moved to auto section wintermodel to get the answer your looking for.............bicboy extreme good behaviour needed flower..bicboy wrote:Bet this gets moved to the Automatix Section, under duress from the moderators
- bicboy
- Main scooter: S2, EID Built, Diablo tuned...
Lam46 wrote:Lol..prob best moved to auto section wintermodel to get the answer your looking for.............bicboy extreme good behaviour needed flower..bicboy wrote:Bet this gets moved to the Automatix Section, under duress from the moderators
Everything must be done to the Extreme.....
A two stroke is a two stroke..
Head temp or barrel temp? I guess the sensor is on the head. 90 tops I'd say.
just looking for a fast running temp from the engine, spark plug would be better.
i understand 90 is for a water cooled engine but i seemed to think air cooled engines run a lot hotter than this.
On the one fitted to Dave Workmans Rally the temp gauge was reading between 220 and 265 degrees fahrenheit. The scoots done a few hundred miles now so I guess on this bike at least thats safe.
Thanks diablo sounds about the right temp for an air cooled
