Gilera Runner VXR 200 Cutting out problems
mr series 2
Main scooter: LI 150 Ser 2
Hope someone can help with problems im having with a runner VXR 200 when coming to a stop the engine cuts out or if it does keep running it then cuts out when trying to pull away again is this a common problem has anyone else had this happen thanks in advance
methleymongo
CHECK THAT THE AIR FILTER ISN'T BLOCKED OR REMOVE IT AND THEN TRY IT....
mr series 2
methleymongo wrote:CHECK THAT THE AIR FILTER ISN'T BLOCKED OR REMOVE IT AND THEN TRY IT....
Thanks for that i will check it
