FINALLY A JL4 Vs ADS1 GRAPH.
Adspeed
Tuned Monza 230 recently came in and agreed to have a play with some pipes....... :)
JL4 Vs ADS1 Race pipe.........
Got some intersesting ones with the ADS3 Rally pipe, post when I get a minute. ;)
Wee Mark
Main scooter: Lambretta TV200
....you,ve gotta be pleased with that, i loved the JL4 on my Rapido 225 but your pipe is revving on even further :D ......result!!!
gadgetman
Am I reading it wrong or is the JL making up to 4 BHP more than the Adspeed all the way up to 8000rpm
T'other way round gadgetman......what appears to be the crossover point in the graph....is the extension point of the ads pipe......ads is up 4 bhp.
bazman
Don't know if i'm reading this correctly.....but is the ads pipe only starting to make power at 6k rpm? And looks like 2hp gain not 4?
Adspeed
bazman wrote:Don't know if i'm reading this correctly.....but is the ads pipe only starting to make power at 6k rpm? And looks like 2hp gain not 4?
On this set up the ADS is about 450-500rpm later up the rev range than the JL4. It does make power lower down its just when Martin starts the reading.
When I look at the graph I like to look at the area say above 20hp on each graph. Doing this you can see that the ADS has at least double the area over 20hp. So yeh pretty pleased with it.
This pipe was the first I designed, only actually meant to put on a TS to take on my Wednesday night lot :D
soullad
gadgetman wrote:Am I reading it wrong or is the JL making up to 4 BHP more than the Adspeed all the way up to 8000rpm
if you compare like revs for revs then I believe you are correct, thou the difference is approx more like 3hp
At say 6000 rpm...jl4 14 hp ads 11 hp
6500 rpm jl4 18 hp ads 15 hp
7000 rpm jl4 22 ads 19 hp
In reality all its really done is shited the power further up the rev range by approx 500 rpm as Ads has quoted. Its beauty lies in its ability to rev on alot more after 8000 rpm....So your gearing, depending on your starting point might needed to be changed to reflect the changes above if swapping between these two pipes.
It a proper seaside screamer :D :D
Any chance of the other graph Ads?
Can someone good at photoshop thicken up the Red line so we can tell which is which?
Any torque graph?
gadgetman
I was correct- up to almost 8,000 rpm the JL is making UP TO 4bhp more ,( ie at 6,500 rpm JL = 18bhp / Ads = 14bhp). The extra revs that the Ads pipe allows between 8,000 and 9,500 rpm is quite impressive but in real life unless you had a 5 speed gearbox the JL wins hands down except perhaps in a 150m sprinter or perhaps a quarter mile sprinter that had gearing set up specifically for that purpose. Having said all that many people like their engines to rev to the max and it would be nice to see the effect of this exhaust on a more mainstream barrel not an extremely rare Monza 230 as we all know the port configuration has as much effect on the power delivery as the design of the exhaust.
bazman wrote: And looks like 2hp gain not 4?
Sorry, was reading it on my phone and the numbers were not clear, i think you are right.
