JL4 Vs ADS1 Race pipe.........
Got some intersesting ones with the ADS3 Rally pipe, post when I get a minute.
On this set up the ADS is about 450-500rpm later up the rev range than the JL4. It does make power lower down its just when Martin starts the reading.bazman wrote:Don't know if i'm reading this correctly.....but is the ads pipe only starting to make power at 6k rpm? And looks like 2hp gain not 4?
if you compare like revs for revs then I believe you are correct, thou the difference is approx more like 3hpgadgetman wrote:Am I reading it wrong or is the JL making up to 4 BHP more than the Adspeed all the way up to 8000rpm
Sorry, was reading it on my phone and the numbers were not clear, i think you are right.bazman wrote: And looks like 2hp gain not 4?
Users browsing this forum: Baidu [Spider], Majestic-12 [Bot], Semrush [Bot] and 7 guests
