Jet 200 Dampers
Bones
Does anyone out there know if anyone is doing repro Jet 200 Dampers (9mm eye holes) OR does anyone know of any replacement dampers that fit?
I have tried Paoli dampers of an Italjet with custom spacers but they are way to hard and don't damp at all!
Any ideas would be welcome!
Fruitjuice
There's a type of Mini-front dampers that seem to fit perfectly, there was a picture of a Lammy Lynx/Lince with them fitted some time ago.
they may fit but they dampen both ways not one way
im sure buzz solo moto does them as a remade item made in the EU as well
can you turn the damping off one way on these mike or just decrease it?
I really don't know Mark, I've not tried them, just read what it says in the description. Personally, I like the BGM dampers.
Bones
BGM dampers
looking at these they appear to have standard 6mm eye ends which means they will not fit the 9mm Jet200 studs
Bones wrote:
BGM dampers
its only a push in insert they come out easily which is good and err bad
panamesc
mark wrote:they may fit but they dampen both ways not one way
like any modern damper ;)
i'm the one with the red and black spax
absolutely no problems , set them soft , ride like a ...... lambretta :mrgreen:
it's even p'n'p 8-)
