power to lights problem 12v
boxofbits
went for ride Sunday light horn worked spot on them got home nothing –
No back light /brake or anything – engine still runs—so thought it may be the stator – seems to be power coming out of it but only read s 4-5 on electric tester on tick over –( wire which goes into regulator box which powers lights) when you rev it picks up easy enough to 8 v then 12 v with a bit more revs
What can it be – checked cleaned all Earths all seems to be ok – the only one I haven’t checked is one on the rear light it seems rusted on so will give that a go tonight
What should it read – should it be 12 v on tick over or higher that 4-5– could it be a stator problem?? engine runs ok but thats it
Do you think its worth buying a new stator?
dapper
Stator won't put out 12V until engine revved up a bit. I'd look in the headset for a loose connection first or dodgy ignition switch.
Daggs
If we are discussing the usual 12V AC conversion, the wire from the stator carrying Vac to the reg. (usually ylw sometimes brown [Indian]) should produce a pretty unstable ac up to around 30volts with gentle revving. The reg. stabilises and regulates it to circa 12v.
boxofbits
so if mine showing 4- 5 volts on tick over and goes to about 8-12 with a gentel rev - if so wouldn’t that point to a dodgy stator? Not producing enough power? for the lights -- ?
Daggs
If you have removed the yellow from the reg. and are checking it to earth on the engine. That voltage seems low. It could be be a dodgy joint on the stator, check 'em.
