A bit boggy - cold weather???
Yanker
Bufficus wrote: Are you as pissed as I am?
Pissed? I AM RANTING. How fukin dare those Degos start sub-strating the Lambretts design with spade connectors and Vespugh stands and idiot lights and uuuugehthpf all that hideous Servetta ignition switch kockation and light switch butplug travesty?
Bufficus
Surely keeping the ignition switch up at high level will keep it dry?
mick1
Main scooter: Li Avanti 225
alanscottj wrote:I'm actually thinking it might just be a power issue, not jetting, been out again and it just feels like its losing power at full throttle. I have a feeling I might have too many toys on it for the power it produces. For example, I have just fitted a SIP electronic speedo, the bike already had a EGT gauge that is back lit, I have had one of those 'mod' chargers on it for ages (but not actually charging anything, but still connected). So, maybe, just maybe I am using too much power. I have also just read on here that I need to change the spark plug to one that suits the SIP speedo, a resistor type plug. All of this combined may well be why I'm losing power top end???
In line with the other posts maybe you should fit a "Barometer" as well..... :?
I agree the power and ignition side are completely separate and the gadgets should not affect the ignition.
Stuck rings may also be a cause for the lack of power.
Timbo
Have you done anything to the carb or filter since the dyno no matter how little?
storkfoot
Have a look at the air/fuel graph on your dyno printout. It may be that Readspeed left the jetting at the top end a tad rich. Then, when you get the really damp air that we have had in the last few days, it is making it too rich.
Yanker wrote:...... S.I.P.(WHATEVERT THAT STANDS FOR)?
Scooter Innovation Parts.
bristolmod
fuel flow? sufficient?
Chris
Scootering since 1968.
alanscottj
Timbo wrote:Have you done anything to the carb or filter since the dyno no matter how little?
Nope, haven't touched it :)
alanscottj
storkfoot wrote:Have a look at the air/fuel graph on your dyno printout. It may be that Readspeed left the jetting at the top end a tad rich. Then, when you get the really damp air that we have had in the last few days, it is making it too rich.
https://fbcdn-sphotos-g-a.akamaihd.net/ ... 5ed463294f
Marty ULC
Main scooter: curry burner GP225 mugello
Carb icing?
