Pissed? I AM RANTING. How fukin dare those Degos start sub-strating the Lambretts design with spade connectors and Vespugh stands and idiot lights and uuuugehthpf all that hideous Servetta ignition switch kockation and light switch butplug travesty?Bufficus wrote: Are you as pissed as I am?
A bit boggy - cold weather???
mick1
- registered user
- Main scooter: Li Avanti 225
- Contact:
In line with the other posts maybe you should fit a "Barometer" as well.....alanscottj wrote:I'm actually thinking it might just be a power issue, not jetting, been out again and it just feels like its losing power at full throttle. I have a feeling I might have too many toys on it for the power it produces. For example, I have just fitted a SIP electronic speedo, the bike already had a EGT gauge that is back lit, I have had one of those 'mod' chargers on it for ages (but not actually charging anything, but still connected). So, maybe, just maybe I am using too much power. I have also just read on here that I need to change the spark plug to one that suits the SIP speedo, a resistor type plug. All of this combined may well be why I'm losing power top end???
I agree the power and ignition side are completely separate and the gadgets should not affect the ignition.
Stuck rings may also be a cause for the lack of power.
storkfoot
- registered user
- Main scooter: '70 GP150 [TS1 225]
- Contact:
Have a look at the air/fuel graph on your dyno printout. It may be that Readspeed left the jetting at the top end a tad rich. Then, when you get the really damp air that we have had in the last few days, it is making it too rich.
- drunkmunkey6969
- Moderator
- Contact:
Scooter Innovation Parts.Yanker wrote:...... S.I.P.(WHATEVERT THAT STANDS FOR)?
bristolmod
- registered user
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
- Contact:
fuel flow? sufficient?
Chris
Chris
Scootering since 1968.
alanscottj
- registered user
- Main scooter: Lambretta GP SS250 Casa
- Contact:
Nope, haven't touched itTimbo wrote:Have you done anything to the carb or filter since the dyno no matter how little?
Lambretta Series 2 Rat - RB260, SuperTourer, Cyclone 5 gearbox ๐๐
alanscottj
- registered user
- Contact:
storkfoot wrote:Have a look at the air/fuel graph on your dyno printout. It may be that Readspeed left the jetting at the top end a tad rich. Then, when you get the really damp air that we have had in the last few days, it is making it too rich.
https://fbcdn-sphotos-g-a.akamaihd.net/ ... 5ed463294f
