More clutch woes!
Bilko
Main scooter: LI150
I'll scan them now and upload them, give me a min.
Bilko's Oily Blog
Bilko
Main scooter: LI150
afclutch by Bilkers, on Flickr
Bilko's Oily Blog
Its gotta be something to do with the chaincase then...its not depressing the clutch at all by the sounds of it.?
10 inch Terror
Xbox live gamer tag: No.
Bilko wrote:I'll scan them now and upload them, give me a min.
Thanks for that Bilko very good of you to help. Ok whats this about the brass plunger? I'm i right in thinking theres 2 differnt ways to fit it, yes? If so whats the correct way? I have a half day tomorrow and i'm going to have another bash at it. It all when together so nice and everything was free moving with no binding, i'm sure it's something simple.
As daft as it might sound 10", check the ground on which you fitted the side case to see if it has fallen out and rolled anywhere...its made of brass, once did that with and engine mount cone and couldnt figure out why the engine moved so much..lol, told you it might sound daft
:freak:
10 inch Terror
SORTED :D ! I took the cassette apart and soaked the plates for 36 hours, re fitted and hey presto it's all ok. Really nice clutch no slipping or dragging the biting point is a wee bit high but i'll get use to that. Thanks for all your advice gentlemen.
so you did have to soak your clutch plates on your new AF clutch...mmmmmm never heard of that happening before.. :frog:
10 inch Terror
Lam46 wrote:so you did have to soak your clutch plates on your new AF clutch...mmmmmm never heard of that happening before.. :frog:
I'll let that one go! ;)
Only cause there was a hapy ending.. :mrgreen:
