Page 2 of 3
Re: Readspeed Lukas Lambretta CDI
Posted: Tue Dec 26, 2017 1:54 pm
by Adam_Winstone
Not a problem, happy to pass on my experience with it.
Posted: Tue Dec 26, 2017 5:29 pm
by garry inglis
yes thanks for that adam sounds very good
Posted: Tue Dec 26, 2017 11:08 pm
by Scooterdude
I see Anthony Tambs is doing a very similar thing. Runs off ac using one of his inteliconverters or can run from the dc feed from the regulator using what he calls a smoothing diode in the feed wire, about £45 I think.
Posted: Wed Dec 27, 2017 2:02 am
by shamrockexpress
essexgp wrote: ↑Tue Dec 26, 2017 1:40 pm Thanks for taking the time to give this feedback, sounds like ill be getting one very soon
plus 1,,,,,,,,,,,
good info Adam
Posted: Wed Dec 27, 2017 10:33 am
by HxPaul
double post.
Posted: Wed Dec 27, 2017 8:22 pm
by HxPaul
HxPaul wrote: ↑Wed Dec 27, 2017 10:33 am
Scooterdude wrote: ↑Tue Dec 26, 2017 11:08 pm I see Anthony Tambs is doing a very similar thing. Runs off ac using one of his inteliconverters or can run from the dc feed from the regulator using what he calls a smoothing diode in the feed wire, about £45 I think.
He also does one now that runs direct from the AC power output on a 3 pin 12v AC regulator,the same as a Lukas CDI.Same price ie.£45.
Posted: Wed Dec 27, 2017 8:47 pm
by firekdp
HxPaul wrote: ↑Wed Dec 27, 2017 8:22 pm
Aren't they just cheap generic Chinese atv/scooter components though?
Posted: Thu Dec 28, 2017 10:23 am
by HxPaul
No idea ! If you have inside information maybe you'd like to share it.
Posted: Thu Dec 28, 2017 12:49 pm
by Adam_Winstone
^... my tuppence worth, I'm aware that Anthony Tambs builds and sells some very good stuff, to the extent of my buying some of his stuff, but I have no experience of his coils or CDIs. As such, all I can comment on is how 'fit for purpose' the Readspeed item is (seemingly excellent).
Posted: Thu Dec 28, 2017 6:52 pm
by firekdp
HxPaul wrote: ↑Thu Dec 28, 2017 10:23 am No idea ! If you have inside information maybe you'd like to share it.
DC CDI
https://www.aliexpress.com/item/4-PINS- ... 4e35d730-8
High Power ignition coil
https://www.aliexpress.com/item/CARBOLE ... eLevelAB=1
