Readspeed Lukas Lambretta CDI
- registered user
- Main scooter: Lambretta GP
- Contact:
Not a problem, happy to pass on my experience with it.
- garry inglis
- registered user
- Main scooter: ts1 230 and rb200
- Contact:
yes thanks for that adam sounds very good
Scooterdude
- registered user
- Main scooter: Lambretta LI 125 S3
- Contact:
I see Anthony Tambs is doing a very similar thing. Runs off ac using one of his inteliconverters or can run from the dc feed from the regulator using what he calls a smoothing diode in the feed wire, about £45 I think.
shamrockexpress
- registered user
- Contact:
- HxPaul
- registered user
- Main scooter: lambretta Li 150
- Contact:
HxPaul wrote: ↑Wed Dec 27, 2017 10:33 amHe also does one now that runs direct from the AC power output on a 3 pin 12v AC regulator,the same as a Lukas CDI.Same price ie.£45.Scooterdude wrote: ↑Tue Dec 26, 2017 11:08 pm I see Anthony Tambs is doing a very similar thing. Runs off ac using one of his inteliconverters or can run from the dc feed from the regulator using what he calls a smoothing diode in the feed wire, about £45 I think.
Aren't they just cheap generic Chinese atv/scooter components though?HxPaul wrote: ↑Wed Dec 27, 2017 8:22 pmHxPaul wrote: ↑Wed Dec 27, 2017 10:33 amHe also does one now that runs direct from the AC power output on a 3 pin 12v AC regulator,the same as a Lukas CDI.Same price ie.£45.Scooterdude wrote: ↑Tue Dec 26, 2017 11:08 pm I see Anthony Tambs is doing a very similar thing. Runs off ac using one of his inteliconverters or can run from the dc feed from the regulator using what he calls a smoothing diode in the feed wire, about £45 I think.
- registered user
- Contact:
^... my tuppence worth, I'm aware that Anthony Tambs builds and sells some very good stuff, to the extent of my buying some of his stuff, but I have no experience of his coils or CDIs. As such, all I can comment on is how 'fit for purpose' the Readspeed item is (seemingly excellent).
DC CDI
https://www.aliexpress.com/item/4-PINS- ... 4e35d730-8
High Power ignition coil
https://www.aliexpress.com/item/CARBOLE ... eLevelAB=1
- Information
Who is online
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 4 guests
