Readspeed Lukas Lambretta CDI
Adam_Winstone
Not a problem, happy to pass on my experience with it.
garry inglis
yes thanks for that adam sounds very good
Scooterdude
I see Anthony Tambs is doing a very similar thing. Runs off ac using one of his inteliconverters or can run from the dc feed from the regulator using what he calls a smoothing diode in the feed wire, about £45 I think.
shamrockexpress
essexgp wrote: Tue Dec 26, 2017 1:40 pm Thanks for taking the time to give this feedback, sounds like ill be getting one very soon
plus 1,,,,,,,,,,,
good info Adam
HxPaul
double post.
HxPaul
HxPaul wrote: Wed Dec 27, 2017 10:33 am
Scooterdude wrote: Tue Dec 26, 2017 11:08 pm I see Anthony Tambs is doing a very similar thing. Runs off ac using one of his inteliconverters or can run from the dc feed from the regulator using what he calls a smoothing diode in the feed wire, about £45 I think.
He also does one now that runs direct from the AC power output on a 3 pin 12v AC regulator,the same as a Lukas CDI.Same price ie.£45.
firekdp
HxPaul wrote: Wed Dec 27, 2017 8:22 pm
Aren't they just cheap generic Chinese atv/scooter components though?
HxPaul
No idea ! If you have inside information maybe you'd like to share it.
Adam_Winstone
^... my tuppence worth, I'm aware that Anthony Tambs builds and sells some very good stuff, to the extent of my buying some of his stuff, but I have no experience of his coils or CDIs. As such, all I can comment on is how 'fit for purpose' the Readspeed item is (seemingly excellent).
Adam
firekdp
HxPaul wrote: Thu Dec 28, 2017 10:23 am No idea ! If you have inside information maybe you'd like to share it.
DC CDI
https://www.aliexpress.com/item/4-PINS- ... 4e35d730-8
High Power ignition coil
https://www.aliexpress.com/item/CARBOLE ... eLevelAB=1
    Users browsing this forum: Ahrefs [Bot] and 13 guests
