Gp flooding or fuel starving
HxPaul
Scooterdude wrote:Ive recently suffered the same scinario going round right hand corners, turned out to be the float set at the wrong height. it was flooding btw....
Theres only one setting for the jetex carb.........
Scooterdude
Float valve, leaking or damaged float then.
dazblakey
garry inglis wrote:Do you get meImage
Yes mate, but I'm running a different filter one that fits the mouth of the carb
Sent from my D6603 using Tapatalk
garry inglis
It won't be that then don't think the jettex is a bad carb I've used a couple of 22mm and once jetted correctly they are great
dazblakey
garry inglis wrote:It won't be that thenImage don't think the jettex is a bad carb I've used a couple of 22mm and once jetted correctly they are great
Been over several times everything checks out
mick1
Main scooter: Li Avanti 225
Could be electrical ? Have you tested the stator ?
dave81
Main scooter: SIL GP 150
I had this problem once when out on a Sunday afternoon ride. On a right hand turn it cut out. Found the choke plunger spring had broken so it allowed fuel to come out of the choke jet. This filled up the breather pipe so when I turned right the fuel ran down into the Jetex and flooded it.
dazblakey
I've checked the stator right ohms etc and checked the choke see no joy
HxPaul
joespeed wrote:and run with the filler cap slack or removed
This is good advice http://www.ilambretta.co.uk/forum/viewt ... cap#p72802
dazblakey
Tried it
