Theres only one setting for the jetex carb.........Scooterdude wrote:Ive recently suffered the same scinario going round right hand corners, turned out to be the float set at the wrong height. it was flooding btw....
Gp flooding or fuel starving
- HxPaul
- Main scooter: lambretta Li 150
Scooterdude
- Main scooter: Lambretta LI 125 S3
Float valve, leaking or damaged float then.HxPaul wrote:Theres only one setting for the jetex carb.........Scooterdude wrote:Ive recently suffered the same scinario going round right hand corners, turned out to be the float set at the wrong height. it was flooding btw....
Yes mate, but I'm running a different filter one that fits the mouth of the carbgarry inglis wrote:Do you get me
Sent from my D6603 using Tapatalk
- garry inglis
- Main scooter: ts1 230 and rb200
It won't be that then
don't think the jettex is a bad carb I've used a couple of 22mm and once jetted correctly they are great
don't think the jettex is a bad carb I've used a couple of 22mm and once jetted correctly they are greatSent from my SM-A320FL using Tapatalk
Been over several times everything checks outgarry inglis wrote:It won't be that thendon't think the jettex is a bad carb I've used a couple of 22mm and once jetted correctly they are great
I had this problem once when out on a Sunday afternoon ride. On a right hand turn it cut out. Found the choke plunger spring had broken so it allowed fuel to come out of the choke jet. This filled up the breather pipe so when I turned right the fuel ran down into the Jetex and flooded it.
I've checked the stator right ohms etc and checked the choke see no joy
- HxPaul
This is good advice http://www.ilambretta.co.uk/forum/viewt ... cap#p72802joespeed wrote:and run with the filler cap slack or removed
Tried itHxPaul wrote:This is good advice http://www.ilambretta.co.uk/forum/viewt ... cap#p72802joespeed wrote:and run with the filler cap slack or removed
