Rapido 250 jetting
- byron
- Main scooter: Li Special; scarred,but sound
a mate has an open carb and a PM pipe, so a bit different, but something to start with...
40 slide
AV268
X7, second clip
130 main
50 idle
mix screw 1¾ out
250 float needle
it does run slightly rich, but is used a lot, and goes on long trips
40 slide
AV268
X7, second clip
130 main
50 idle
mix screw 1¾ out
250 float needle
i agree
I have tried all the combinations,
clip positions,needles and atomisers,
having available:
AV 264,AV 266, AS 266
X7, X13, X2
It took me ages,
I found out that he best set up with 48mm RM pipe,62mm crank,Breathe Sweet filter,
is:
Slide 40
Pilot 55
Choke 70
Main 122
X13, T2
AV 264
300 Float Valve
2 turns out mixture screw.
Everything else makes the scooter running rich or lean.
Main can drop to 120,but I prefer 122.
having available:
X7, X13, X2
It took me ages,
is:
Slide 40
Pilot 55
Choke 70
Main 122
X13, T2
AV 264
300 Float Valve
Last 2 weeks I changed from 4.8 to 4.5 final drive ratio.
+drop in temperature.
Main jet changed from 122 to 128.
- Main scooter: Lambretta Li 250 Special
Hi,
had mine set up on the dyno at B-Race tuning.
PHBH 30 carb remote air filter. ScootRS expansion pipe 4.7 final ratio.
Slide 40
Pilot 55
Choke 70
Main 122
X7, T2
AV 266
300 Float Valve
1 1/2 turns out mixture screw.
Slide 40
Pilot 55
Choke 70
Main 122
X7, T2
AV 266
300 Float Valve
Another setting that works
PHBH 30 carb Tino's remote filter,RM big bore
Slide 40
Pilot 52
Choke 70
Main 128
X13, T1
AV 266
300 Float Valve
Slide 40
Pilot 52
Choke 70
Main 128
X13, T1
AV 266
300 Float Valve
