Rapido 250 jetting
wack 63
Main scooter: '71 GP TS1
I am planning to fit a PHBH 30 with elbow and filter to a Rapido 250 and wondered if anyone else was using similar as a guide.Motor runs a Taffy mk 4. Thanks
a mate has an open carb and a PM pipe, so a bit different, but something to start with...
40 slide
AV268
X7, second clip
130 main
50 idle
mix screw 1¾ out
250 float needle
it does run slightly rich, but is used a lot, and goes on long trips
goldeneye
i agree
Dimitrios_231
I have tried all the combinations,
clip positions,needles and atomisers,
having available:
AV 264,AV 266, AS 266
X7, X13, X2
It took me ages,
I found out that he best set up with 48mm RM pipe,62mm crank,Breathe Sweet filter,
is:
Slide 40
Pilot 55
Choke 70
Main 122
X13, T2
AV 264
300 Float Valve
2 turns out mixture screw.
Everything else makes the scooter running rich or lean.
Main can drop to 120,but I prefer 122.
Dimitrios_231
Last 2 weeks I changed from 4.8 to 4.5 final drive ratio.
+drop in temperature.
Main jet changed from 122 to 128.
phil23fair
Hi,
had mine set up on the dyno at B-Race tuning.
PHBH 30 carb remote air filter. ScootRS expansion pipe 4.7 final ratio.
Slide 40
Pilot 55
Choke 70
Main 122
X7, T2
AV 266
300 Float Valve
1 1/2 turns out mixture screw.
Dimitrios_231
Another setting that works
PHBH 30 carb Tino's remote filter,RM big bore
Slide 40
Pilot 52
Choke 70
Main 128
X13, T1
AV 266
300 Float Valve
