s.i.p tubless rims
Danger
Main scooter: lambretta TV200
anyone been using these vespa tubless rims on there scooter for any lenght of time wanting to know if anyones tried before i buy an what there like all round in general thanks Darren
johna
Playstation gamer tag: vespatx200
Got them on my vespa only had them on for about 4 months so can not say how good yet.Tyres was easyer to fit than other tubeless and they r a good looking wheel imo.If you do get some put the gunk in and the good stuff not the £6 a bottle stuff.
johna
Image hope this works :shock:
LI150
Main scooter: Series 2 LI150
had a look at these at Brid custom show they look the buisness and are on my wish list
Danger
smart looking scooter m8, those are the rims i was looking at , when you said use tyre gunk did you use it to inflate the tyre completely or an air /gunk mix thanks again
johna
You need to take the valve out so tyre is flat then put the gunk in (there is enough in the bottle to do 3-4 wheels its about £25 ) then put valve back in and pump up to normal 18 front 28 back i think.
I think the wheels come with the valve in now did not when i got mine.So if the valves are the same as mine and your drum is the same as mine you might have to dremel a bit out of the drum cus the valve will be to tight.If yours is a disc (star hub)i think they fit ok.Hope all that helps :D
Danger
thanks for that, im putting them on my MK1 T5 with px disc setup so should be ok , now to find the cheapest place in uk to get them thanks again
johna
buzzsolo was selling them at one of the shows £45 i think.
I want to put a disc on mine would not mind seeing a pic of yours at the handle bar end. :shock: :D
Danger
mine isnt built yet but will be keeping it the standard look at the handlebars cable operated using the master cylinder mounted on the front forks
johna
Ok no prob m8 i think i know the one u will be using
