standard ts port timings
fred
Anyone know what standard ts 225 port timings are?
thanks,fred
ArKaTxU
fred wrote:Anyone know what standard ts 225 port timings are?
thanks,fred
Maybe this can help you. Is from ScooterCenter:
jason frost
thanks,fred
:shock: dont tell me you are going TS
fred
no chance!!, Just measured a mates and it's 132 transfers,and 188 exhaust :freak:
not messed with,but i thought standard exhaust timing like that a bit extreme.
hows it goin?
fred
fred
thanks for the port map,but i used a degree disc,umpteen times!! And still came to the same conclusion. It's got 1mm deck clearance,so doubtfull its a 60 stroke crank. just found it odd. sounds like a crosser,even with a standard indian flywheel.
camel
those transfers are rather high,mines about 127...has it got a thick base gasket or packer?may be std but if someone has jacked the barrel up your timings are going to be more like what you have,could poss be your casing too
jason frost
fred wrote:no chance!!, Just measured a mates and it's 132 transfers,and 188 exhaust :freak:
hows it goin?
fred
All going well, we need to sort a night out :o
Sounds about right, all to high try them in the port timing thing Eden did.
Wayne Miller
thanks,fred
Using the port Map above I get . . . . . .
Deck Height -1 (58mm stroke 107mm conrod)
Ex 180.02
Tr 127.26
Deck Height 0 (58mm stroke 107mm conrod)
Ex 176.05
Tr 122.57
Deck Height +1 (58mm stroke 107mm conrod)
Ex 172.03
Tr 117.26
Or 60mm stroke . . . . .
Deck Height -1 (60mm stroke 107mm conrod)
Ex 184.90
Tr 135.62
Deck Height 0 (60mm stroke 107mm conrod)
Ex 181.11
Tr 130.91
Deck Height +1 (60mm stroke 107mm conrod)
Ex 177.28
Tr 126.06
Stay tuned..............
