JB Tuning ScootRS Anti-Dive Conversion
battlam
Main scooter: Lambretta gp
Those sip calipers are the danglies! The only thing is the fork lug looks 10mm to high to me. Its not marking the parrellelagram that it should. I dont think you'll have a problem with it like that though. I've found those calipers are smoother operating than the scoot rs ones.
not an anti dive expert.......... anyone?
It does look like that in the picture but the wheel is off the ground, hanging over the workbench, there is some debate over the parallelogram theory though :-?
battlam
are the forks chrome powdercoat? its very hard to see in pic but they look smart!
Yes, forks hubs and rims in chrome powdercoat by Trestan Finishers in Southampton, highly recommended ;-)
soulsurfer wrote:It does look like that in the picture but the wheel is off the ground, hanging over the workbench, there is some debate over the parallelogram theory though :-?
no i think that position is spot on
guygrrr
Main scooter: 1980 Vespa P187
so this is the JB set up?
what does it include?
more can do, less doodoo.
No, this is the Worb5 MMW setup, this is what you get with the 220mm disc, mine has the 200mm disc as the 220 won't fit with the SIP caliper...
It comes in kit form and requires bearings, seals, spindle, spacers, half nuts and speedo drive parts from a drum hub.
this is my spare cs one
and yes it works very well
sydduckett
rbgaz wrote:hi soulsufer, could u explain what u mean by re machine correctly ?
cheers
What he means Gaz is that
theres some form of bush for it to pivot on perhaps... :o
Got her fired up this morning, but kept cutting out every 500 yards. Lucky the last one wasnt far from home as i had push it back in the p1551ing down rain.... :cry:
