47/16 LI150 on a std TS1 225 TMX35 JL3 is it a good set-up?
damdam
Hi mates,
this gear set up should have 4,99 as final ratio, is it a good choice?
I'm searching for a tourer set-up with torque.
Thanx
Dam
camel
i run a 16x46 on a li 150 box with a similar set up to give 4.8 ratio.which is perfect and a good general ratio for a torquey pipe
the thing with gearing is you have to find what works for you ....so its trial and error really....see how you get on with it :D
I had 17/46 with a Devtour and it was awful into headwinds and uphill, I changed to 16/47 and I love it, I'm 12 stone ish and don't ride two up with loads of luggage.
Hope this helps ;-)
carbon lammy
run same as you soul and i am very happy with it,good all round set up.
martinr
16/46 is a better setup a jl3 will pull 4th pretty well giving you good top end 75-80 ish
the-brickie
Xbox live gamer tag: cap willard
I'm running a SX200 box and standard sprockets on my TS and love it, sure if I drop revs I have to drop a gear but love the re rush of taking off again, changing down at approx 60 and leaving some vespas coming up behind me coming home from Mersea down the A12 was a high light! :D
I've also got a standard 4 plate clutch, some old crappy springs I found in my box of bits, old chain tensioner, old stretched chain and I treat it with the utmost disrespect, flys along!
Should have mentioned the 32mm delly Vhsa and crappy old NK modded to run on a rubber mount cos its so old that its starting to fracture all over the place, I've lost the end can three times recently! :lol:
Diablo
I like this combination (16/47LI150). Ran it in my own TS and have built more than a few for customers.
Don't use stretched chains in anything so wouldn't consider 16/46. 17/46 as Mike says is a little tall.
Mag
Main scooter: Carbon GP TS1
Built my mate Roy a TS engine with this set up and Dev tour exhaust. He loves it! It accelerates very well and is short enough to tour loaded with luggage. Used 81 link chain (don't like stretched chains)
ArKaTxU
Remember that you can use Variochain from LTH for configurations that need stretched chains.
    Users browsing this forum: Ahrefs [Bot] and 2 guests
