Anyone have any info on hiding the front brake hydraulic hose via the normal drum brake cable route? I know you have to turn down the throttle rod in a lathe.Am I right in thinking the hose has to be slimmer than normal? If so, will this still be suitable for a double disc set up?
Thanks.
Hidden front brake hydraulic hose.
Ihateyoubutler
- registered user
- Contact:
I used stainlees pipe as far as the throttle wheel.I will take some more photo's for you this week as you cant see anything "That was the idea"
- carlos fandango
- registered user
- Contact:
I didnt have to on mine, as the Jason frost method. but i didnt need to turn the rod down. I used the plain s/steel braided hose 6mm OD.Ihateyoubutler wrote: I know you have to turn down the throttle rod in a lathe.
- jason frost
- Dealer
- Contact:
carlos fandango wrote:the Jason frost method
The Jason frost method worked for me as well
Angry Bloke
- registered user
- Contact:
jason frost wrote:carlos fandango wrote:the Jason frost method
Please enlighten us
Unless its similar to the rhythm method.
- byron
- registered user
- Main scooter: Li Special; scarred,but sound
- Contact:
dash it, I saved this link to the old LCGB forum, but the photos have gone... should've saved the pics too...Angry Bloke wrote:jason frost wrote:carlos fandango wrote:the Jason frost method
Please enlighten us
It was very tidy
- jason frost
- Dealer
- Contact:
Angry Bloke wrote: rhythm method.
Ihateyoubutler
- registered user
- Contact:
Thanks for the help. Just a couple more questions, what diameter does the rod need to be turned down to and do I need a particular master cylinder? ( Haven't bought one yet).
Thanks again.
Thanks again.
Didn't turn the rod down just drilled cable inner hole out to 6.5mm and use a STD scootrs master
- Information
Who is online
Users browsing this forum: Baidu [Spider], Google [Bot], Semrush [Bot] and 12 guests
