Hidden front brake hydraulic hose.
Ihateyoubutler
Anyone have any info on hiding the front brake hydraulic hose via the normal drum brake cable route? I know you have to turn down the throttle rod in a lathe.Am I right in thinking the hose has to be slimmer than normal? If so, will this still be suitable for a double disc set up?
Thanks.
DJB
I used stainlees pipe as far as the throttle wheel.I will take some more photo's for you this week as you cant see anything "That was the idea"
carlos fandango
Ihateyoubutler wrote: I know you have to turn down the throttle rod in a lathe.
I didnt have to on mine, as the Jason frost method. but i didnt need to turn the rod down. I used the plain s/steel braided hose 6mm OD.
jason frost
carlos fandango wrote:the Jason frost method
:D
The Jason frost method worked for me as well
Angry Bloke
:D
Please enlighten us
Unless its similar to the rhythm method. :)
Angry Bloke wrote:
:D
Please enlighten us
dash it, I saved this link to the old LCGB forum, but the photos have gone... should've saved the pics too...
It was very tidy
Ihateyoubutler
Thanks for the help. Just a couple more questions, what diameter does the rod need to be turned down to and do I need a particular master cylinder? ( Haven't bought one yet).
Thanks again.
Didn't turn the rod down just drilled cable inner hole out to 6.5mm and use a STD scootrs master
    Users browsing this forum: Semrush [Bot] and 12 guests
