dt 175 piston
sjc
getting my 80s yamaha conversion barrell back,,is there any-one who can supply a piston with the windows welded up or is there an altenative one i could use..many thanks steve.. ;)
J1MS
I bought a few of the DT175 pistons from Dave Webster back in the 80's which were all welded.
I don't know of a version without windows, but I started using a reed valve with a little additional porting and much larger inlet timing, it made the engine more ridable with no spit back.
Might be an option ?
sjc
thanks j1ms,,porting wise it was taken to its max,,was mick haymens race barrel,,wot reed block are you using? cheers steve v.s.s.c ;)
J1MS
sjc wrote:thanks j1ms,,porting wise it was taken to its max,,was mick haymens race barrel,,wot reed block are you using? cheers steve v.s.s.c ;)
jonny snatchsniffer
if you cant get one you can use a cr250 piston, but you would need to change the rod for one with an 18mm smallend bearing
    Users browsing this forum: No registered users and 25 guests
