Dowty Seals / copper sealing washers
YAMLAM
Having trouble getting weeping/ leaks from my hydraulic front brake banjos ,all items are new and i have tightened the banjo bolts up as tight as i can.
on my other hydraulic disc ( a DJ webster item from 84` :D ) it uses Dowty seals instead of copper washers , anybody else use these ? and anybody know what size the standard copper washers are on a ScootRS hydraulic outboard disc brake ?
win or lose have a booze
newmanlammy
Most disk brake hoses use a M10 fine bolt thread. Dowty washers or bonded seals as they are known as usually come in bsp sizes but it is possible to get metric ones and I may have some M10 at work, i'll have a look tomorrow for you.
YAMLAM
many thanks.
newmanlammy
Found a few M10 dowty's for you to try, pm me your address and I will post them to you.
roadrunnerian
i used dowty washers on my hyd brake system they worked a treat. :D
YAMLAM
Pm sent .
Thanks.
sydduckett
How good was that..... :D
The main problem is the shank is too long on the RS banjo bolt and bottoms before it crushes the washer.
YAMLAM
i recon your right wack, two mates have had the same problem, hoping the dowty`s are slighly deeper, otherwise ,it`s grinder time . :lol:
wack 63 wrote:The main problem is the shank is too long on the RS banjo bolt and bottoms before it crushes the washer.
what he said also the bango can vary in thickness i had this prob when i changed the standard scootrs hose for a stainless one from a well known dealer i ended up using a bolt from a dragster as there about 3mm shorter
    Users browsing this forum: Google Adsense [Bot] and 8 guests
