on my other hydraulic disc ( a DJ webster item from 84`
Dowty Seals / copper sealing washers
Having trouble getting weeping/ leaks from my hydraulic front brake banjos ,all items are new and i have tightened the banjo bolts up as tight as i can.
) it uses Dowty seals instead of copper washers , anybody else use these ? and anybody know what size the standard copper washers are on a ScootRS hydraulic outboard disc brake ?
win or lose have a booze
- newmanlammy
- Dealer
- Main scooter: Animal worldwide freeride
Most disk brake hoses use a M10 fine bolt thread. Dowty washers or bonded seals as they are known as usually come in bsp sizes but it is possible to get metric ones and I may have some M10 at work, i'll have a look tomorrow for you.
many thanks.
- newmanlammy
- Dealer
Found a few M10 dowty's for you to try, pm me your address and I will post them to you.
roadrunnerian
i used dowty washers on my hyd brake system they worked a treat.
Pm sent .
Thanks.
Thanks.
sydduckett
How good was that.....
i recon your right wack, two mates have had the same problem, hoping the dowty`s are slighly deeper, otherwise ,it`s grinder time .
what he said also the bango can vary in thickness i had this prob when i changed the standard scootrs hose for a stainless one from a well known dealer i ended up using a bolt from a dragster as there about 3mm shorterwack 63 wrote:The main problem is the shank is too long on the RS banjo bolt and bottoms before it crushes the washer.
- Information
Who is online
Users browsing this forum: Baidu [Spider], Google [Bot], Semrush [Bot] and 17 guests
