BGM Rear Light Reflector
leehuggy72
yes mine's very bright and looks the bizz
got mine from broady's
coaster wrote:It's really simple to convert a GP rear light housing to take the LED but it is a non-reversable process. You just need to carefully cut the raised part of the reflector off (I used a wood saw) so that it is level with the outside of the housing and then use plastic metal to glue the LED board into the housing taking care not to bridge the copper strips on the rear of the board with ther filler (just in case it is conductive enough to cause problems.
Whole job took 30 minutes 8-)
I cut the lugs off with a dremmel and then used some perspex sheet cut to the shape of the light housing and glued that in place, then drilled a hole in it for the wires and fitted a grommet to keep the elements from getting to the LED board, then drilled a hole at each corner of the LED and screwed it into casing using small washers to space the LED board away from the perspex, job dome. Much less hassle if you've got the flat housing like Lam46 though.
Timbo
they fit the early early GP lights with little modification, the later curved ones are easily cut with a dremmel then stuck on with silicone.....fantastic lights....... 8-)
Bilko
Main scooter: LI150
Thanks for the help lads. Got mine today via Corrado and it wasn't hard to modify with the dremmel & some silicone.
Bilko's Oily Blog
dapper
Bilko wrote:Thanks for the help lads. Got mine today via Corrado and it wasn't hard to bodge with the dremmel & some silicone.
:lol: :lol: :lol:
Bilko
Main scooter: LI150
What are the colours Red, yellow, black on the BGM reflector?
Bilko's Oily Blog
Philipp
the wiring is like this:
black = earth
red = brake light
yellow = rear light
cheers philipp
philipp@scooter-center.com
0049 (0) 2238 -307459
Bilko
Main scooter: LI150
Thank you Philipp
Bilko's Oily Blog
so do as I said in my email.
your brake light is DC, so that will work already.
but your rear light is AC, so will only work with the engine running, but you can use the battery to test the wiring.
Bilko
Main scooter: LI150
I don't get it.
I have a back light without the engine running, but when I press the back brake light the light goes out.
Nothing happens when I use the front brake light.
I don't know how to test with the battery. :oops:
Bilko's Oily Blog
