imola tuning by mick abbey
J1MS
RG 500 bearing, if you do later stroke out the motor to 60mm a recessed head Either stepped or doweled would be best IMO
But I think Mick would be best placed to advise, I like the fact he's kept the transfer timings low looking for more port area with aditional ports and widening the original transfers.
rocho68
hi guys , got my baby running but havin trouble with the jetting , starts first kick but as you try and ride through the gears she splutters and pops then if you wang the throttle back she takes off like a rocket , any ideas ?
rocho68
forgot to tell you , av 268 atomizer , 125 main jet ( tried 135 and 145 ) 55 pilot and x2 needle (when it says set on 2 clip is this from the bottom of the needle or top ? help !!!!!!!
col265
rocho68 wrote:forgot to tell you , av 268 atomizer , 125 main jet ( tried 135 and 145 ) 55 pilot and x2 needle (when it says set on 2 clip is this from the bottom of the needle or top ? help !!!!!!!
I'd say 2nd clip is 2nd from top. Try an AV266.
Do you run an air filter? 125 sounds small, and as Col says try 264
rocho68
hi dan , its not running an air filter , with the amount of tuning i would have thought it would need a bigger main jet too , what sort of base setting would you start at and would a different pilot make any difference ? looks like i need to get it up to you to get it set up correct !!!
carlos fandango
I saw this scoot in the flesh at the "summer session" and it looked amazing, 8-) loved all the subtle modifications ;)
Did it win anything ?
Special X
Try an X13 needle on 2nd clip.
soullad
J1MS wrote:RG 500 bearing, if you do later stroke out the motor to 60mm a recessed head Either stepped or doweled would be best IMO
Aye, have always thought, amongst other things, that transfer timings around 125 deg help promote a torquey set-up. Probably helps with encouraging scavenging and maximising the blow down time.
rocho68
carlos fandango wrote:I saw this scoot in the flesh at the "summer session" and it looked amazing, 8-) loved all the subtle modifications ;)
thanks carlos , heres how i made the disk brake cover and rev counter holder !!!ImageImageImageImageImageImage
    Users browsing this forum: No registered users and 28 guests
