Sprockets & Chain Combination
My Mk1 muggy 28/30 pwk, sito ancilotti, has an Li 150 box and 16/46 and I'd say 2 up it sometimes struggles especially into headwinds. I'm 12 stone and the mrs is 8 stone, any more weight and I'd definately be looking to go to a 15 front sprocket
rog60
Main scooter: Indian GP200
If you download the PDF copy of Scooter Center Colognes' catalogue there is a handy gear calculator/what length chain goes with what sprocket set-up included.
camel
people seem to forget the std li150 box 15x46 is the same final drive as the std gp200,ive built a ported 186 with a 28 delly and clubman for a friend,this bike shames a lot of higher spec lamys and is a joy to ride with this std box,you wont go far wrong leaving it with a 15x46 set up
my ts1/pm28/35tmx and my rapido 250/ancolitti/ tmx35mm both run 16/46 on li150 boxes , ts1 has been gps'd @ 83mph (i bottled b4 bike did :oops: ) where as my rapido pulls gps'd 65 at half throttle and will not pull more (2 up with 60kilo in trailer):evil: so im now changing pipe for a mk1 pm.
my dac 250 is being built to pull 19/46 on a li150 box :shock: :P
DMC
The TS 250 I did for Trev Green has always run Li 150 21/46 on the road.
