Jetex Jets
kejj
Hi all.
I'm looking to upgrade my jetex sh22 SOI-100 with some decent del'orto jets.
Problem is that I can only make out the small jet that's a 50.
The other 2 I cant make the figures out. The choke jet just has a 1 on it and the mainjet seems very long and only says 5.
My engine is a SIL GP200, I have a scootrs stainless steel exhaust.
What are the standard recommended jet sizes for this setup? Which equivalent Del'orto Jets match this carb?
Best
/K
________________________
http://tv175.wordpress.com/
bristolmod
main jet 123
Pilot 45
starter 50
Atomiser 5899/2
slide 7895/1
Scootering since 1968.
kejj
bristolmod wrote:main jet 123
Pilot 45
starter 50
Atomiser 5899/2
slide 7895/1
And the Delorto parts for hte SH2 carb fits and are interchangeable?
bristolmod
jets and atomiser certainly are. The slide should be although I've never had the need to substitute one
kejj
bristolmod wrote:jets and atomiser certainly are. The slide should be although I've never had the need to substitute one
GReat thanks, dunno why I should change the slide though. Got any reason for the suggestion?
Special X
Just change the jets, standard main is 118 but 123 sounds good with ScootRS pipe.
I'd really advise you not to change the slide. In my experience you can't mix and match slides or it will run poorly.
kejj
Doom Patrol wrote:I'd really advise you not to change the slide. In my experience you can't mix and match slides or it will run poorly.
Cool, thanks 4 the tip.
    Users browsing this forum: Ahrefs [Bot], Baidu [Spider] and 2 guests
