Unable to Centralize Front Wheel
Here you go, would this solve it with a disc hub spindle
No half nut required.
Bilko
Main scooter: LI150
You have just been promoted to Colonel Legend.
Pm on the way.
Bilko's Oily Blog
Bilko
Main scooter: LI150
Balls!!!!
Just nipped out half naked to have a look and the one I have is the same! Aaaarrrrrggghhhhhhhh!
Now I'm f@@ked!
Your promotion still stands by the way
Bilko's Oily Blog
Are you sure? The Spaq one doesn't have the recessed groove around the cut out for the stub on the link. The recessed groove allows you to remove the nut on the spindle on the plate side and for the stub to seat in the recessed groove. Soulsurfer's is a scootRS one. You can't remove that thin nut unless you have the recessed groove in the plate. It pulls the hub over by a couple of mm.
Post a pic bilko
Bilko
Main scooter: LI150
Your right.
I was only looking at the recess where the nut goes.
Bilko's Oily Blog
carlos fandango
i had the same problem ended up getting the hub machined down 5mm to get it central
chisel
post a photo of the righthand side of the wheel/caliper mount so as i can see which spindle you have,i should be able to let you know what to do then.Martin
Bilko
Main scooter: LI150
Soul Surfers sending me his thingmie, so hopefully that will sort it.
Bilko's Oily Blog
Bilko
Main scooter: LI150
chisel wrote:post a photo of the righthand side of the wheel/caliper mount so as i can see which spindle you have,i should be able to let you know what to do then.Martin
Is this ok?
Bilko's Oily Blog
