Fork spring height issue
Bilko
Main scooter: LI150
Is there a height that the springs should sit at?
To me this looks too high, even though I don't have spring stops in.
By the way, don't get excited. That's not an extremely large condom in the back ground it's a rubber glove
Bilko's Oily Blog
Are you sure you haven't got anything left inside the forks?
Who's springs are they and how long are they?
Bilko
Main scooter: LI150
Progressive fork springs from SR @ 215mm
99% sure there's nowt left in. :?
Bilko's Oily Blog
My MB ones measure 223mm but these have been used so may have compressed a little. Shine a small torch down to have a look. Does the rod pass through the spring and into the hole at the top okay?
bristolmod
if it was a condom, I certainly wouldn't call it large anyway........................ :shock:
Scootering since 1968.
Bilko
Main scooter: LI150
Now sorted. With special thanks to lammy mark for supplying the 12mm threaded bar!
Thanks for the help SS
Bilko's Oily Blog
No problem, what was up there?
Bilko
Main scooter: LI150
There was old Stops inside the forks, when I originally thought there wasn't. Thanks to a previous post by yourself with the mention of a 12mm threaded bar and the help of lammy mark bringing round a 12mm bar, the problem was solved!
Bilko's Oily Blog
Happy Days :-)
Can't take credit for threaded bar idea tho', that came from Sean Brady ;-)
    Users browsing this forum: Google [Bot] and 9 guests
