Legshield Toolbox Rubber
Bilko
Main scooter: LI150
Has anyone used anything other than the rubber supplied?
Mine isn't very subtle and doesn't sit well on the cut out in the middle for the legshields. I was hoping someone had any ideas as to a better sollution.
Bilko's Oily Blog
bristolmod
try the rubber door seal from a scrap car- cheap as chips down your local scrap yard.
Try and get a narrow one- have used it before in a different application and it covers a multitude of sins.
Scootering since 1968.
i used a vespa px one it was longer and wider and very subtle mine came from totally scooter
Bilko
Main scooter: LI150
Thanks lads.
Bilko's Oily Blog
Danger
Main scooter: lambretta TV200
bilko mucker have you tried putting it in boiling hot water an leaving it to soften or i have one here off my MK1 T5 you could try b4 you buy lets is know as im only round the corner from ya
Bilko
Main scooter: LI150
That's what I always did on my old Lammies Danger but I was hoping for a better rubber. I've just done with what I've got. Thanks anyway.
Bilko's Oily Blog
Danger
nae probs m8
I thought that the Viet supplied one was the same as the Vespa one, it's far better than the rubber that comes with the indian ones. The issues I had with mine was that by the time I'd trimmed enough off the toolbox for it to fit flush there wasn't enough of a gap around the area where the brackets are so it doesn't want to stay in place. Maybe there's a specific glue that can be used to bond the rubber to the metal. Brackets that come separately to be positioned after you get the shape right would have helped too.
    Users browsing this forum: Semrush [Bot] and 13 guests
