Hydrolic clutch
carlos fandango
Fux
Main scooter: li150 S2
How`s that been treating you carlos?
carlos fandango
Fux wrote:How`s that been treating you carlos?
8-) So far so good, its off the road at the moment ( not clutch related :) ) Its in a rb200 and its a four plate clutch with strong springs. I wouldnt say it was a two finger operation and not as light as i had hoped :oops: but lighter than before :)
Fux
Well, mine is a 2 hand operation at the mo.... :oops:
What make was it, looks like I could set one of those up pretty easily. I like the fact that its easier to take the engine out.
carlos fandango
Fux wrote:Well, mine is a 2 hand operation at the mo.... :oops:
Its a magura hymec from Venhill about £70.00 a quality product. they do various ones the only problem with them is that the travel on them is only about 10mm so you need a way to adjust them to get it in the right position.
An easier solution is the hebo ones that come as a kit http://www.trialsbits.co.uk/index.php?cPath=79 (the universal ones in the photo, but look out of stock) this is part cable operated so the slave cylinder can be fitted anywhere ;)
Russ
    Users browsing this forum: Majestic-12 [Bot], Semrush [Bot] and 7 guests
