Mikuni+ Taffspeed TS1 225
bendikb
Hi
I could not find this combo in any other post. Please feel free to point me in the correct direction If I missed a post.
Set up;
Mikuni carb
Tasserini reed
TS1 225 w/ Taffspeed road tune
MBD piston
Taffspeed road exhaust
HPC crank w jap rod conversion
Af flywheel with Indian stator so no variable ignition as for now..
Any ideas on where to start?
bendikb
Nobody? There ought to be somebody out there with a similar TS1 and TMX 35?
Try searching here first, there are a few setups you can compare: http://scooterotica.org/forum/viewtopic ... 14&start=0
Also, your second post now states it is a 35mm so people can at least make some suggestions, you'll probably find that a good starting point is something like this:
Standard slide, 56 needle, 2nd clip, 320 main, 20 pilot.....start there and lean/richen up as your setup requires according to plug chops. If happy then crack on, if you want a more precise setting and/or peace of mind, then get it booked in at your local scooter dyno specialist.
bendikb
Thanks! I'll use that as a starting point. I can assure that my local sooter shop does not have a dyno :lol:
