knocking noise on scoot rs anti dive
- soulsurfer
Steve, that's not the case with anti dive, that lug isn't used. I'm using disc links, if using drum links, the lug on the link has to be removed so the caliper plate can rotate. It's then held by the tie bar to the fork leg and the assembly then pivots on the spindle and tie bar like a parallelogram within suspension travel.
red ghost
- Xbox live gamer tag: Pleasure Master
- Main scooter: lambretta gp150
soulsurfer wrote:
Is this the Worb5 unit?
- sean brady scooters
- Dealer
one thing to watch out for,is spindle nuts (especially domed or pike ones) hitting shockers..
sydduckett
Gaz, i told you that by buying of Randle and saving a few pence you would be looking at a false ecconomey....
Now Ill tell you again stop buying ting tong rubbish.
By the by if you wanna pop over and pick up the end can tonight no worries, swapped some rings with JB for a 2nd hand one yesterday and fits like a glove....
ok i understand cheers for putting me right i dont have any knowledge of these brakes but that makes sense as that will allow both sides of the hub to move slightly when the brake is appliedsoulsurfer wrote:Steve, that's not the case with anti dive, that lug isn't used. I'm using disc links, if using drum links, the lug on the link has to be removed so the caliper plate can rotate. It's then held by the tie bar to the fork leg and the assembly then pivots on the spindle and tie bar like a parallelogram within suspension travel.
- soulsurfer
Yes. Not cheap but superb solution with quality and looks IMO.red ghost wrote:Is this the Worb5 unit?
red ghost
soulsurfer wrote:Yes. Not cheap but superb solution with quality and looks IMO.red ghost wrote:Is this the Worb5 unit?
What worries me is how does a 'Dirty Sanchez' fit into it?
- soulsurfer
God knows
I did ask if I could have it without the engraving
sydduckett
How much is the worb anti dive and will it bolt staright on to a scootrs set up?
- soulsurfer
It's a complete kit that requires some donor parts, it's not an upgrade kit and isn't compatable with any other brake setup except maybe some parts of the LTH brakes.sydduckett wrote:How much is the worb anti dive and will it bolt staright on to a scootrs set up?
The SIP caliper additional.
- Information
Who is online
Users browsing this forum: Google [Bot], Majestic-12 [Bot], Semrush [Bot] and 2 guests
