sips speedo
plantman
any one got one of sips speedos to fit rally head set ? how does it calculate speed.? looks like a nice peice of kit :bouncing:
Here's a video and some info...
http://www.streetfire.net/video/the-all ... 995800.htm
More info...
http://issuu.com/sip-scootershop.com/do ... _english_2_
It says speed measurement is made in the same way as original, implying it uses the cable. I would assume that it uses a magnetic pickup or something as it's a digital speedo :-?
BTW anyone know the diameter of the round one? I assume that's the Vespa P80-150X/PX80-200 E/P200E one?
plantman
thanks hope it uses a pick up some how.i think the round one is v90
C*NTSPEED
out of stock but soon as it comes back in im on it looks proper bo it does
GEMINI S.C.
BLACK WIDDA'S S.C.
C*NTSPEED
plantman wrote:thanks hope it uses a pick up some how.i think the round one is v90
I was hoping the same as my hub eats speedo drives any way the add in the catalogue clearly states that it runs of the speedo cable and no add on sensors required im after one but apparently the next batch is sold out even before they got them in i hope thats a wind up
GEMINI S.C.
BLACK WIDDA'S S.C.
Diablo
I've emailed SIP with your queries and I'm waiting for them to get back to me.
C*NTSPEED
Diablo wrote:I've emailed SIP with your queries and I'm waiting for them to get back to me.
hope you get a response shortly i been waiting 3 days :roll:
GEMINI S.C.
BLACK WIDDA'S S.C.
sibyl
you find a pretty detailed description here:
http://www.sip-scootershop.com/EN/Produ ... 200E+.aspx
no magnetic pickup. one of the trial versions had one, but it works better the way it is constructed now...
ESC #700
joeythescooterboy
It still doesn't say whether it uses the standard speedo drive set up?
Like Joe's mine goes through speedo cables and drives like no one's business, at one point I was going through a cable every 50 miles!
Also is it only available in KMs or MPH too.
Nice bit of kit but not much use if it's off the normal speedo set up.
Nemo saltat sorbius, nisi infanus est.
C*NTSPEED
joeythescooterboy wrote:It still doesn't say whether it uses the standard speedo drive set up?
IT DOES MPH TO IT SAYS JOEY :lol:
GEMINI S.C.
BLACK WIDDA'S S.C.
